April 6, 2012, 22:02 |
Negative Fuselage Drag on a Tandem Wing?
Mike
Rep Power: 15 |
Hey guys,
So, I am modeling external flow over a tandem wing aircraft in Star-ccm+. The domain size looks sufficient, the volume mesh looks good, the solution has converged and has been run for 3500 iterations, and I have double checked the force vector and force monitor orientations. I have divided the reports into component and total values for lift and drag, and the overall total values for lift and drag look good. The other sub-components lift and drag values (front wing, rear wing, and tail) all look good except the fuse, which has a negative drag value. When I run the fuse just by itself, it has a positive drag value and reasonable down force. So, my question is: in conjunction with the other aircraft components for a tandem configuration is it possible to have a negative drag value for the fuse component? Thanks! Mike |
April 7, 2012, 05:52 |
Depending on the shape of your fuselage, it's unlikely but it may actually be possible.
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 18:22 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
multi wing element - negative coefficient of drag? | Zweeper | FLUENT | 10 | March 11, 2010 13:20 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
