Residual
Old   September 24, 2005, 18:48
Default Residual
Beni
I am looking for a good way of calculating the residual of Pressure Correction. I think it should be very simple to calculate the mass-imbalance of all cells divided through inlet massflux. So far so good, but if I am making this the error is always approximately zero because I am extrapolating the velocities at the outletboundary and correct it then to assure global mass conservation (like in the Peric Code CAFFA)! Where is my error in my thinking, or is there another better way of calculating the residual, also for further pressure correction equations like in PISO?! Thank you for your help!
transsonic nozzle with rhoSimpleFoam Unseen OpenFOAM Running, Solving & CFD 8 July 1, 2022 07:54
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 06:24
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 12:16
