Convergence rate
Old   September 22, 2005, 05:44
Default Convergence rate
Davoche
Hi everybody, I have a relaxation scheme for a Poisson equation. I have implemented both Dirichlet and Neumann Boundary Conditions. But I notice that the Neumann condition required more iteration to converge. Is it a right behaviour?
Old   September 22, 2005, 11:25
Default Re: Convergence rate
agg
It is possible depending on your solution technique that more iterations are required with a Neumann bc.
When you have a Dirichlet bc, only one solution for Poisson equation is possible, since the solution must relax to that at the boundary. With a Neumann bc however, infinite solutions are possible, since only the zero derivative condition needs to be satisfied i.e at the boundary d(variable)/dn = 0
Convergence Centurion2011 FLUENT 48 June 15, 2022 00:29
Force can not converge colopolo CFX 13 October 4, 2011 23:03
error and convergence rate HaKu Main CFD Forum 0 April 28, 2011 18:39
Convergence rate of SimpleFoam boddyouareboy OpenFOAM 0 January 25, 2011 04:49
Convergence Rate Study Khurram Main CFD Forum 1 May 15, 2002 06:05
