Grid resolution in porous medium model for heat sink
Old   March 27, 2012, 12:59
Default Grid resolution in porous medium model for heat sink
Chander is on a distinguished road
Hi
I am simulating conjugate heat transfer in a heat sink consisting of a number of parallel microchannels.
Since modeling each microchannel is computationally inefficient, I am modeling the heat sink using the porous medium model (this is a well established approach in literature).
Now, if I understand correctly, the porous medium model equations are derived for what is called as the Representative Elementary Volume (REV) that is assumed to be much larger than the average pore size.
In my case the average pore size is of the order of channel width.
So following the above REV assumption, what minimum grid size can I go to while checking for grid Independence? Should I ensure that my average grid size is always much larger than the channel width? If yes, then how much larger it should be than the channel width?
Thanks for your inputs.
Chander is offline   Reply With Quote
Old   March 28, 2012, 13:57
Andrew
mettler is on a distinguished road
are you checking your answer against experimental data? When I did a fluent model based on my physical model, I was comparing the data. Therefore, I could do a grid check based on that. I think you might want to try different different grid densities and see how that affects your answer.
It was a few years ago that I did my porous media model. When I did it I had to have various coefficients in order for Fluent to solve the equations. I had to obtain those from my lab experiment. Is this your case too?
mettler is offline   Reply With Quote
Old   March 30, 2012, 06:26
Hello Andrew,
Thanks for your reply.
No I do not have experimental data to check my simulations against it.
However, I have repeated the simulations for three grid densities, of average sizes 0.5h, h and 2h where h is nearly equal to the channel width.
And the results of three simulations fall on a trend that is typical of a grid independent study. In other words, the results do not change drastically when i refine my grid.
So, is it safe top conclude that the grid size can go below the pore size in porous medium and is independent of the way the differential equations are derived for porous medium?
Old   April 2, 2012, 11:11
Rami Ben-Zvi
Rami is on a distinguished road
The porous model aloows one to treat the micro-structure (micro-channels in your case) as averaged continuum. Once this was done, refining the grid to check the solution grid independence may use grid smaller than the REV, but do keep in mind that doing so does not mean you resolve the micro-structure - you only validate solution of the continuous equation system is converging.
Rami is offline   Reply With Quote
Old   April 2, 2012, 11:56
Thanks Rami for your reply.
Your explanation does make a lot of sense.
I will check if I get the same behaviour when I use non-thermal equilibrium model for Porous medium (actually your explanation suggests that I should get the same behaviour)
Thanks again
Chander
Source Term UDF VS Porous Media Model pchoopanya Fluent UDF and Scheme Programming 1 August 28, 2013 07:12
How to use non-equilibrium thermal model for porous medium in Ansys CFX 13.0? Chander CFX 3 November 28, 2011 15:26
porous medium J Siemens 2 January 24, 2007 07:09
Discrete phase model in porous media Pradeep FLUENT 0 February 3, 2006 17:30
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 06:59
