how to calculate the performace paramters of a savonius TWISTED blades vertical wind |
March 24, 2012, 09:42 |
asif
Rep Power: 14 |
hello..i am optimising a SAVONIUS TWISTED BLADES VERTICAL WIND TURBINE with two blades.i have made 6 cad models of this trbine with increasing angles and did the CFD of all and got all the presure and velocity contours.
now the problem is that i want to make three performance graphs of this wind turbine which will help me select the optimum of all these.I AM NOT DOING ANY EXPERIMENTS AS I HAVE NOT FABRICATED THIS WIND TURBINE.. THE THREE GRAPHS I WANT ARE TORQUE VS THE TWISTED ANGLES MECHANICAL POWER VS TWISTED ANGLES COEFFICIENT OF POWER VS TWISTED ANGLES. i do not know how to make these graphs using the data(contours) obtained in ansysys.. thank you.. urgent help needed .. i have attached the pdf document which has an example |
Vertical Axis Wind Turbine Rotating Domain Problems | TWaung | CFX | 4 | May 1, 2012 03:14 |
Analyses and Design of Wind Turbine Blades, please help!!! | heavymag | Main CFD Forum | 7 | April 13, 2012 16:51 |
2D Simulation of Savonius Wind Turbine | ravindersingh | FLUENT | 4 | December 9, 2011 13:00 |
Savonius wind turbine | enry | FLUENT | 0 | December 3, 2009 19:45 |
angular velocity in vertical wind turbine | vanni | FLUENT | 1 | April 23, 2009 02:44 |
