Equation of state
Old   September 18, 2005, 18:17
Default Equation of state
Edward
Hello all, I am new in CFD and I am trying to learn by myself. I run across a problem while trying to simulate a compression by mass augumentation in a 2L vessel. The problem is that I do not have the equation of state for water valid at high pressure above 800 MPa and high temperatures avobe 100C. I have a paper from Saul and Wagner "A fundamental equation for water covering the range from the melting line to 1273 at pressures up to 25000 MPa" sounds that I have it but there is not equation there, can somebody help me on this. I will really appreciate it. Thanks in advance By the way I am trying to model using fluent that I am learning too.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 01:58
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
