Cannot get the right result
Old   September 18, 2005, 12:49
Default Cannot get the right result
Eric
I'm currently doing a CFD project. This project is actually a simulation of a modeled truck in a wind tunnel. I need to calculate the Drag Coefficient of the truck. Everything is done as calculated and estimated but the result seems to be wrong. I had the formula right and the others seems ok. I suspect is the result from the simulation. Anything u all need to help me solve this problem or any tips on how to solve it, please let me know. Thanks a lot.
Old   September 30, 2005, 15:08
Default Re: Cannot get the right result
ganesh
Dear Eric,
This is rather tricky but I have the following suggestion. If the order of your experimental and computational results are nearly same or not much different, the roughness in the model could be playing a role. And then it becomes necessary to know the conditions you are simulating and the true conditions that actually existed. Any discrepancy in data could result in erroneous results. I believe that the drag is the single-most important factor in such a simulation and has to be correctly estimated. Thats all with the information I can gather from your question.
Hope it helps
Ganesh
Comparison the airfoil 0012 experimental result and simulation result harrislcy FLUENT 30 August 29, 2013 11:27
Low pressure result in low velocity region for RNG-ke? Gabbee90 OpenFOAM Running, Solving & CFD 0 July 14, 2011 21:48
Read Result Files or User Defined Result Aquilaris ANSYS 0 February 9, 2011 06:25
In a distance above the ground, my LES result is not good panda60 OpenFOAM 2 January 22, 2010 08:52
LES result harrislcy FLUENT 1 December 28, 2009 07:29
