How to determine delta t for free surface flow
Old   September 14, 2005, 12:52
Default How to determine delta t for free surface flow
phsieh2005
For single fluid flow, one generally use Courant number to determine delta t. How about flows with free surface?
Someone gave me this criterion in the past:
dt < min (SQRT((rho/sigma) (ds/PI)^3))
where rho is density, sigma is surface tension coef, ds is the cell length along the interface.
Is this correct? Does anybody knows where this comes from? Thanks!
phsieh2005
[ICEM] Automatic mesh generation script surface intersection problem stuart23 ANSYS Meshing & Geometry 0 May 13, 2011 02:10
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
mass flow rate on the Iso-clip surface & interior Sunil Gupta FLUENT 0 April 22, 2008 10:29
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
Turbulence model in flow driven by surface tension Z. ZENG Main CFD Forum 7 April 28, 1999 08:18
