3D DNS code in C with large arrays.
Old   July 5, 1999, 08:25
Default 3D DNS code in C with large arrays.
S.Sri Govind
I've been trying to run this code that simulates turbulent spots for Couette flow.The code runs perfectly for a grid of 70*37*70, but gives a segmentation fault for a grid of 134*37*134. I've managed to track down the problem to a particular function, which is not able initialise the array (of the above size) fully.When I ask for the values to be printed before being sent to the function,the segmentation fault seems to occur when about 70 odd points are to be initialised.This occurs even when I Try to initialise only a part of the whole grid say 100*33*100.
Old   July 5, 1999, 08:58
Default Re: 3D DNS code in C with large arrays.
Andrei Chernousov
You may use memory allocation function of the type:
#include <stdio.h> #include <process.h> #include <alloc.h>
/* Memory allocation procedure based on _nested_ pointers, w/o segmentation problems */
/************ * RECTMEM * For 2D (rectangular) array ************/ float **RectMem( int columns, int rows ) { float **x; int i;
if((x=(float**)farmalloc(columns*sizeof(float*)))= =NULL) {
printf("cannot allocate"); exit(0); } for( i = 0; i < columns; i++ )
if((x[i]=(float*)farmalloc(rows*sizeof(float)))==NULL) {
} return x; } // end RectMem( )
// Good luck!
Old   July 6, 1999, 04:00
Andrei Chernousov
Excuse me, I posted message without preview
Memory allocation procedure based on _nested_ pointers, w/o segmentation problems (For 2D (rectangular) array):
include stdio.h
include stdlib.h
include alloc.h
float **x; int i;
if((x=(float**)farmalloc(columns*sizeof(float*)))= =NULL) { printf("cannot allocate"); exit(0); }
return x;
} // end RectMem( )
Old   July 23, 1999, 14:09
clifford bradford
master i do not understand. could you explain what it is you're trying to do so that a plebian like myself can comprehend
The FOAM Documentation Project - SHUT-DOWN holger_marschall OpenFOAM 242 March 7, 2013 13:30
What is the Better Way to Do CFD? John C. Chien Main CFD Forum 54 April 23, 2001 09:10
Free DNS code ? Dr. Jones Main CFD Forum 8 November 7, 2000 20:44
own Code vs. commercial code Bernhard Mueck Main CFD Forum 10 February 16, 2000 11:07
State of the art in CFD technology Juan Carlos GARCIA SALAS Main CFD Forum 39 November 1, 1999 15:34
