March 16, 2012, 11:36 |
Large Eddy Simulation and Isosurface
sheth roh
Rep Power: 15 |
In many research papers the wake is shown with isosurface of eddy viscosity and vorticity. I wanted to know what is significance of such isosurface and what can be understood by isosurfaces of such fluid properties.
Additionally, I am confused about LES turbulence model. Actually many low reynolds number analysis employ LES, so application of LES to some problem is determined by flow reynolds number or some other flow characteristics, if yes can you please describe which ones. I have referred fluent manual and have read about turbulence models but still I need to clear up the where to apply LES. Thanks in advance. |
March 17, 2012, 18:00 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
I suggest to disregard Fluent manual for LES ... try reading some books, e.g. Sagaut. Isosurface of a variable is not specific of LES, it is used in laminar as well as in DNS flows. Often one tries to get some idea of vortical structures in turbulence and uses isosurface of vorticity components or pressure... but detection of coherent structures requires much more than such a visualization |
March 18, 2012, 00:19 |
#3 | |
sheth roh
Rep Power: 15 |
March 18, 2012, 04:55 |
Rep Power: 73 |
vorticity is only a dependent variable, its isosurface does not define a core of a vortex ... coherent vortical structures are defined differently and, to tell the truth, their definition is not univocal... you can find useful infos on this topic in the book of Lesieur on LES
March 19, 2012, 08:22 |
#5 | |
sheth roh
Rep Power: 15 |
how to export x- and y-axis of isosurface ? | Tom | CFX | 6 | May 31, 2006 14:19 |
