March 11, 2012, 21:06 |
Sailplane Modelling in Salome Platform
I am fairly new to Salome, and am currently using it to model a high performance sailplane for a project concerned with reducing drag by introducing lower winglets. This is the first complex model I have attempted to create in Salome, and have been building by manually entering keypoints (I am running Salome on Windows 7). When I came to taper the wing, I scaled the wing profile down and displaced the keypoints to the wing tip. The profile is made up of 121 keypoints in both cases, and in each case I created 5 Bezier Curves to link them, before creating a planar face from the Bezier Curves. I tried to extrude from the bigger face to the smaller face (and vice versa) but could not find a command on the GUI that would create a solid, tapered wing. Each wing also has an un-tapered section going from the large planar face to the fuselage, which I simply extruded. I thought I had managed to build the tapered sections when I utilised the GUI via New Entity > Blocks > Quadrangle Face to create faces between corresponding curves, but I noticed a discontinuity between the quadranglular and planar faces when I tried to create a shell and solid from the section. I am also unable to make the un-tapered part of my wing solid, as it does not end with a face on the fuselage (I do not know how to do this, so I simply extruded a little into the fuselage and used the FUSE command). I realise that my problems may be beginner stuff but I would very much appreciate any help. If you PM me I can send you my model for reference. Thanks, David |
plane, sailplane, salome, winglet |
Numerical investigation of wind behaviour around a marine platform | MarTar | ANSYS | 11 | July 29, 2012 11:22 |
Modelling unsteady 2D aerofoil drag | xlxc34 | Main CFD Forum | 0 | June 24, 2011 05:42 |
Salome and Code Saturne simulation of simple room and objects | cristian.ocnarescu | Main CFD Forum | 0 | June 21, 2010 11:19 |
salome, openfoam and moving mesh | prhlava | OpenFOAM Running, Solving & CFD | 8 | November 9, 2009 09:59 |
Advice on multi-phase flow modelling | Martin | Main CFD Forum | 3 | October 14, 2008 06:16 |
