turbulent kinetic energy in TGV case
Old   March 11, 2012, 08:57
Post turbulent kinetic energy in TGV case
baraban55 is on a distinguished road
Hello!
I try to use Two-equation - eddy viscosity model for Taylor-Green Vortex case with Re=3000. I use physical space code with weno3 scheme. I don't want to transport neither turbulent kinetic energy nor turbulent dissipation so I looking for an appropriate models. Kindly ask you to help me.
baraban55 is offline   Reply With Quote
Old   March 11, 2012, 12:35
cfdnewbie
cfdnewbie is on a distinguished road
I'm not sure what you are trying to do and what you are asking for....so you are doing an LES, and you are looking for a SGS model? Is that it? I don't understand your comment about using the k eps model without using the appropriate transport equations.... ???
cfdnewbie is offline   Reply With Quote
Old   March 11, 2012, 14:23
Thank you for your reply. Actually I'm trying to do RANS. I use this model: http://www.cfd-online.com/Wiki/Linea...scosity_models. For eddy viscosity I use the same model as in k-epsilone model with C=0.09. So I'm wondering if it is possible not to transport k and epsilone but model them in case of TGV? What models for k and epsilone can be implement in that case? I would really apreciate any help.
Old   March 11, 2012, 14:35
Old   March 11, 2012, 14:59
cfdnewbie
Dear baraban,
I'm not sure if a RANS approach will get you anywhere with this problem. The TGV is highly unsteady and strongly governed by vortex interaction, so a RANS approach (which does not resolve any eddies) will not give you a good approximation. if you just want to check that, then RANS is fine, but for much else, LES will be needed!
Old   March 11, 2012, 16:03
Dear baraban,
But in my case I don't need a good aproximation. I just want to find rough model for turbulent kinetic energy and turbulent dissipation for TGV. May be than I'll compare the results I'll get with 2 transport equations and models for k and epsilon.
I can also get some DNS results for evalution of turbulent kinetic energy and put it to the k-epsilone model. Than I'll get the limit of prediction for that model for TGV case so I can compare the results of rough models for turbulent kinetic energy with that limit.
I tried to find some models on google and on wos but failed. I also checked it in "Turbulent Flows" by Pope and didn't find the answer. May be you can suggest some other source of searching? I would really appreciate any help).
Old   March 12, 2012, 17:12
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
As previously stated by cfdnewbie, the Taylor-Green vortex case is usually studied to check model capabilities in predicting transition to turbulence in a setting which does not involve boundary conditions or walls. As long as i understand the Taylor-Green vortex case and the URANS turbulence models you wont get any help from any source as it has never been done with URANS. The reason is that it is really out of the modeling capabilities of the URANS approach so no one tryied to get an answer which could never be useful in practice. Nonetheless, you can clearly do the job in any case; just take any available reference on TGV and do the same simulation with your model of choice.
The first reference which comes in my mind is by Fauconnier et al., some work of Drikakis et al., Hickel and maybe someone at Stanford (try to look in the CTR material from the last 5-6 years)
Also, the initialization of this flow is very easy (compared to HIT) so its everything really straight... except that you have to somehow set your initial condition for the URANS turbulence model. This is going to be awkward...
sbaffini is offline   Reply With Quote
inviscid, k-epsilon model, modeling cfd, turbulence, turbulence kinetic energy
question about turbulent kinetic energy junker4236 Main CFD Forum 19 April 19, 2017 05:46
Mean Kinetic Energy alastormoody11 STAR-CCM+ 1 January 19, 2011 10:48
Production of Turbulent Kinetic Energy johndeas OpenFOAM 1 December 14, 2010 10:22
Turbulent Flat Plate Validation Case Jonas Larsson Main CFD Forum 0 April 2, 2004 11:25
Why FVM for high-Re flows? Zhong Lei Main CFD Forum 23 May 14, 1999 14:22
