Finding angle from line1 to line2 in ccw sense(2d)
Old   September 8, 2005, 23:28
Default Finding angle from line1 to line2 in ccw sense(2d)
zonexo
does anyone know of an algorithm which can find the angle from line1 to line2 in ccw (counter clockwise) sense (2d)? Angle between 2 lines can be found easily using dot product. however, the answer given is always < 180deg.
i'm currently using this algorithm, which seems quite inefficient ...
1. find angle of line1 & 2 wrt x axis 2. find which quadrant each line is pointing in 3. from the above 2 ans, deduce the angle from line1 to 2 in an ccw sense
e.g. if line1 & 2 are in 1st quadrant, 60deg & 40deg respectively so angle = 340deg
problem with this code is that there's as much as 16cases to consider.
Does anyone know of a shorter and more efficient algorithm? Thanks
Old   September 9, 2005, 05:06
Default Re: Finding angle from line1 to line2 in ccw sense
upwind
I just thought of a shorter algorithm which I think should work but this needs to be verified; whether it is efficient also needs to be checked out.
1. Determine dot product as before and obtain the cosine
of the angle.
2. Determine cross product i.e. line 1 X line 2 and this
will give sine of the angle.
3. If sine and cosine are both positive or both negative
the take the angle obtained in 1. as it is. If not
define your counter-clockwise angle as 360 - the angle
obtained in 1.
Let me know if this works for you.
Old   September 9, 2005, 07:40
zonexo
Ya i just found it on the web too. it's should work. thanks anyway. btw, the website is http://www.vb-helper.com/index.html. the algorithm is given in visual basic.
finding flow angle pvrao CFX 4 June 3, 2015 08:50
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
Normal vector, slope and aspect angle g_niro Main CFD Forum 0 February 2, 2011 18:24
finding flow angle in linear cascade analysis kiran CFX 3 April 17, 2008 23:43
