Fluent - Convergent Divergent Nozzle
Old   March 7, 2012, 15:36
Default Fluent - Convergent Divergent Nozzle
ANH
aero777 is on a distinguished road
I have used an inviscid compressible flow model for carrying out an analysis of the flow-field.
I have plotted the variation of the Mach number with distance along the nozzle from predictions of 1D theory as well as Fluent's results at the centreline and the wall.
My predictions were that the 1D theory would more closely correlate to Fluent's result at the centreline but the curve is in fact almost halfway between the distance of the 2 curves by Fluent - nothing too conclusive.
My main Q is : What accounts for the differences in the plotted curves?
Attached is a typical graph; position x=0 refers to the throat.
aero777 is offline   Reply With Quote
Old   March 8, 2012, 07:41
Narendra Gadwal
narendra.gadwal is on a distinguished road
Send a message via Yahoo to narendra.gadwal Send a message via Skype™ to narendra.gadwal
http://instruct1.cit.cornell.edu/cou...zzle/step4.htm
narendra.gadwal is offline   Reply With Quote
Old   March 8, 2012, 09:23
ANH
Originally Posted by narendra.gadwal View Post
I am aware of this page. Is it down to the choice of solver or numerical errors from the grid generation?
Old   March 8, 2012, 09:56
aerogt3 is on a distinguished road
I would expect very little error from the grid.... a structured 1-D grid should be quite good quality, no?
aerogt3 is offline   Reply With Quote
Old   March 8, 2012, 23:27
Narendra Gadwal
Why don't you run the simulation considering turbulence ?
Viscosity can also appear because of flow. (Turbulent viscosity)
Convergent Divergent Nozzle Hrishikesh Main CFD Forum 12 June 25, 2016 03:06
Solid Rocket Nozzle - Fluent 5 Tutorial Guide Ijaz FLUENT 4 April 2, 2015 21:46
Flow simulation in a Pelton turbine nozzle fivos FLUENT 0 April 19, 2011 12:46
Master node in parallel computing only distirubtion syadgar FLUENT 1 September 8, 2009 17:41
Pressdrop across in nozzle: Fluent Paul Main CFD Forum 8 January 15, 2006 03:24
