grids in tip clearance
Old   September 6, 2005, 10:35
Default grids in tip clearance
iceraining
hi,everyone.
my model is a axial pump,and the tip clearance is very short to the whole radius. and i met a problem for grids.
when i make ogrids for blade,i don't know where to put the ogrids vertices between the shroud and blade tip. and some grids are always wrong with small angel ,such as 0-9 degree. how to avoid this situation?
thank you very much!
Old   September 8, 2005, 17:17
Default Re: grids in tip clearance
Mani
Do you really need a grid in the tip clearance? Most of the time a tip clearance model is quite sufficient, avoiding the trouble to create a grid in that region. If you really want to grid it, you will need a more complex multiblock topology (assuming you are using structured grids), to get a grid of good quality.
Old   September 12, 2005, 01:50
iceraining
thank you very much! i have finished the structrued grids
[ICEM] Turbine blade with filleting and tip clearance Pursuor ANSYS Meshing & Geometry 4 July 7, 2010 14:56
Meshing in tip clearance. me Siemens 0 August 25, 2008 04:20
grids between tip clearance iceraining CFX 2 September 7, 2005 09:11
Tip Clearance Liam CFX 3 September 7, 2005 06:30
Tip Clearance Drona CFX 0 October 17, 2002 06:25
