help! air viscosity versus pressure
Old   August 30, 2005, 16:22
Default help! air viscosity versus pressure
lin
Does anybody know the relationship between the air's viscosity and the pressure(0.1 to 10000 times of the atmosphere pressure)? Thanks a lot!!
Old   August 30, 2005, 17:00
Default Re: help! air viscosity versus pressure
Buch
1. Link the pressure to the temperature with some classical compressible fluids relations 2. Use the power or Sutherland's law which give the viscosity as a function of the temperature
Old   August 30, 2005, 17:42
lin
thank you Buch!I am in the field of electrostatics,and I am working on eletrohydrodynamic flows.In my case the temperature is constant and only the pressure changes.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
reversed flow at pressure inlet and turbulent viscosity is limited.... cfdiscool FLUENT 10 June 10, 2015 07:15
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Properties of air versus temperature AND pressure Vincent Main CFD Forum 5 July 28, 2008 07:28
help! air viscosity versus pressure lin Fidelity CFD 2 November 3, 2005 23:43
