entropy fix for Riemann problem
Old   August 26, 2005, 22:04
Default entropy fix for Riemann problem
vivek kumar
HI, i am B.Tech 3rd yr student doing mechanical engg. in IIT
Guwahati. I made a code for Roe method in one dimension
using entropy fix from the book E.F.Toro Riemann solvers
and Numerical Methods for fluid dynamics. But this code
eventhough working for small shocks failed to capture High
shocks. Please, suggest me what should i do for high
shocks.
Old   August 27, 2005, 03:17
Default Re: entropy fix for Riemann problem
Munikrishna
Hi Vivek,
Please use the Steger Warming and Van Leer's scheme to start with. Make sure that the results are fine and later experiment with Roe scheme.
Old   August 28, 2005, 02:58
vivek kumar
hi, thanks for ur response. but i have experimented with vanleer .it is working well. please tell me how to fix my problem.
Old   August 31, 2005, 08:47
B787
What exactly do you mean by small shocks and high shocks ? and what is the 1-D problem are you looking at?
[Commercial meshers] Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 maverick OpenFOAM Meshing & Mesh Conversion 2 June 18, 2011 05:36
Velocity profiles problem behind the elbow (3D problem) kabat73 FLUENT 8 May 9, 2010 05:26
Entropy jump across shocks Dave Main CFD Forum 8 March 12, 2008 11:21
roe solver with entropy fix mehdi Main CFD Forum 1 February 26, 2006 06:36
Periodic flow boundary condition problem sudha FLUENT 3 April 28, 2004 09:40
