Implement neumann boundary condition for nondimensional energy equation
Old   February 24, 2012, 17:29
Default Implement neumann boundary condition for nondimensional energy equation
Peter
new_at_this is on a distinguished road
I have written a code to solve the non dimensional temperature distribution in a 2D plane for a given velocity field. I have defined the non dimensional temperature as:
\theta = \frac{T_w-T}{T_w-T_0}
T_w = wall temperature
T(x,y) = temperature
T_0 = Inlet temperature
I have successfully simulated dirichlet boundary conditions. However I am not sure how to implement neumann boundary conditions for a constant heat flux. If someone could offer some pointers I would appreciate it.
Thanks
new_at_this is offline   Reply With Quote
Old   February 24, 2012, 18:59
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Consider the Neumann condition (dimensional)
q = -k dT/dn, at a surface with n unit normal outward to surface, then from your definition you simply get:
q = k (Tw-To) dTheta/dn
The quantity q /k (Tw -To) is a known term of your problem so you have hust to discretize the derivative at the surface
FMDenaro is offline   Reply With Quote
Old   February 25, 2012, 14:10
Peter
How would I know Tw? The only thing that I have defined at the boundaries is q.
Old   February 25, 2012, 14:40
you have to know (Tw -To) from data of your physical problem
Old   February 27, 2012, 14:44
Peter
So i'm missing something. Say i'm solving for a flow through parallel plates. The initial condition is that theta is 1 everywehere.
If I am solving for a constant wall temperature, then I can set the boundary conditions for theta to be 0 at the surface of the plates. I haven't used Tw or To anywhere.
So for the constant heat flux case, shouldn't I be able to do the same by defining some boundary condition on the wall that does not involve dimensional values? Also Tw will change as the flow progresses, shouldn't I be solving for this in the code instead of inputing it?
Old   February 27, 2012, 16:56
Andrew
mettler is on a distinguished road
Can you define Tin? I'll check when I get a chance, but I think I solved your model knowing Tin and then backing out the Tw based on the q..It's been a long time. But, I do think you will have to have a temp defined somewhere
mettler is offline   Reply With Quote
Old   February 27, 2012, 17:49
the quantity q /k (Tw -To) is substantially the Nusselt number, therefore you can fix an arbitrary Nusselt value for your numerical purposes without taking care of your physical values.
Of course you cannot say what is the physical problem until you specify (Tw-To) ...
Old   February 29, 2012, 14:41
Mazhar Iqbal
mazhar is on a distinguished road
Energy equation is an elliptic differential equation. Therefore, you will not be able to solve by defining neuman conditions on all boundaries.
mazhar is offline   Reply With Quote
Old   February 29, 2012, 17:01
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
I guess his T0 at inlet is used in a Dirichlet sense
sbaffini is offline   Reply With Quote
Old   February 29, 2012, 21:19
Mazhar Iqbal
Then he must be solving a thermally developing flow
Old   March 9, 2012, 12:15
Peter
So I am able to define Tin, however I am trying to find the nusselt number for this particular flow. Therefore I can't define the temperature at the wall but only the gradient. I have made some progress but I am getting kinda stuck.
I have redefined my non dimensional temperature to be
\theta = \frac{T_L-T}{T_L-T_{in}}
Where T_L is the the temperature at the end of the heated section calculated by q=m*c_p*(T_L-Tin). As a result I find that
T_L = T_{in} + \frac{q'' L_H}{\rho H L_D C_P}
\frac{\theta_1 - \theta_w}{\Delta y} = \frac{q''}{k(T_L-T_{in})}
This way I should be able to define a neumann condition at the boundary. This logically makes sense however I think that my dimensionless temperature field should be roughly bounded by 0, however my code seems to run to negative theta which is confusing me at the moment.
Alternately I have seen some texts define theta as
\theta = \frac{T-T_{in}}{q''\frac{H}{k}}
When I work out the boundary condition with this definition it is strange because the gradient no longer becomes dependent on q'' so I am confused. Could someone perhaps verify that the first formulation I have for theta is correct and that my code is just doing something wrong?
Old   March 9, 2012, 12:50
your temperature field should be bounded 0<= theta<=1, this is if the correct reference quantities are chosen
Old   April 23, 2018, 19:52
Default How to deal with non dimensional energy equation?
  #13
Jing
serene6390 is on a distinguished road
Hi, peter,
Could you tell me more about how did you deal with non dimensional energy equation? When you set your boundary condition, you set your temperature as a number between 0 and 1? And you talked about using an UDF, what did you use the UDF to define? Boundary condition?
Thanks a lot.
serene6390 is offline   Reply With Quote
Old   May 17, 2018, 10:56
Rami Ben-Zvi
Rami is on a distinguished road
... A bit late, but still...
If you normalize the temperature that way, than the (normalized flux) = flux*(Tw-T0)/K. It therefore follows that the dimensional prescribed flux is replace by the normalized BC: (prescribed normalized flux) = d(theta) / dn where n is the normal coordinate.
Rami is offline   Reply With Quote
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Viscosity and the Energy Equation Rich Main CFD Forum 0 December 16, 2009 15:01
boundary condition for species equation zhou1 FLUENT 1 June 3, 2004 17:15
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 07:18
Boundary Conditions Jan Ramboer Main CFD Forum 11 August 16, 1999 09:59
