results for flow past flat plate normal to flow
Old   August 26, 2005, 11:42
Default results for flow past flat plate normal to flow
lisa
hi everyone, to verify the capabilities of my code to model separation from an immersed zero thickness boundary i am running the 2D test case of flow past a rigid flat plate normal to the flow. i am finding it very difficult to source published experimental or numerical data for this test case - i would be grateful for any suggestions for either the steady case (v low Re cases with attached vortices) or the unsteady case (higher Re with vortex shedding).
thanks very much
Old   August 26, 2005, 15:57
Default Re: results for flow past flat plate normal to flo
Adrin Gharakhani
Koumoutsakos, P. and Shiels D.: Simulations of the Viscous Flow Normal to an Impulsively Started and Uniformly Accelerated Flat Plate . ( J. of Fluid Mech.,Vol. 328, 1996, pp. 177-227.)
Old   August 30, 2005, 17:36
lisa
cheers, lisa.
Laminar flow over a flat plate Nick R CFX 3 November 21, 2010 20:43
incompressible, 2-D laminar flow flat plate varunjain89 Main CFD Forum 1 March 4, 2010 07:59
Seperated Flow and Turbulence modelling flat plate Simon Mizzi Main CFD Forum 1 December 16, 2003 02:26
Free convection flow over vertical flat plate Polly Main CFD Forum 1 February 11, 2003 14:25
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
