High Re K Epsilon vs Low Re K Epsilon
Old   February 20, 2012, 10:21
Question High Re K Epsilon vs Low Re K Epsilon
Ruonin is on a distinguished road
Hi folks,
I am somewhat new to CFD (only been doing for some months ), and I have a doubt which I hope some can clear...
I am trying to implement a Low Re K-Epsilon turbulence model to a backstep and compare it to a High Re K-Epsilon turbulence model, to show that, in this particular case, the Low Re K-Epsilon turbulence model represents the situation better.
However, I get a pressure drop that is higher for the Low Re K-Epsilon turbulence model than the pressure drop for the High Re K-Epsilon turbulence model...
Is this correct? shouldn't it be the opposite?
Or perhaps I made a mistake in the modelling step?
Hope someone can help!
Best Regards,
Rui Silva
Ruonin is offline   Reply With Quote
Old   February 22, 2012, 11:49
Anyone?
I'm really stuck in this matter...
Old   February 22, 2012, 20:34
Julien de Charentenay
julien.decharentenay is on a distinguished road
Send a message via Skype™ to julien.decharentenay
Hi Rui,
In this specific case, you will need to ensure that the mesh is appropriate to the model employed (and ensure that the wall treatment is correct).
Low-Reynolds k-epsilon turbulence model:
- The first cell y+ should be around 1 (or less);
- the wall treatment is based on first cell being the viscous sub-layer.
High-Reynolds k-epsilon turbulence model:
- the first cell y+ should be around 15-30;
- A high-Reynolds wall treatment is to be used.
From your post, I am unsure that you are using two different mesh that are consistent with the employed model.
Kind regards,
Julien
julien.decharentenay is offline   Reply With Quote
Old   February 23, 2012, 10:17
Hello Julien,
thank you for your reply.
What I am doing is modifying the standard high Reynolds k-epsilon (according to Wilcox) that comes with a cfd software (comsol) so that it becomes the
Launder-Sharma Low Re k-epsilon Turbulence model.
So I modified the equations to incorporate the new set of damping functions and boundary conditions near the wall.
After reading some posts and papers I have refined my mesh.
But since I am using a modified standard k-epsilon model, I cannot see y+!
I have attached pics of my mesh near the wall and some size info!
Hope the pics help...
Is there a way to evaluate y+ for a low re k-epsilon model??
Best Regards,
Rui
Old   February 23, 2012, 20:56
Have a look at: http://www.cfd-online.com/Wiki/Dimen..._wall_distance for the definition of y+ - which can be evaluated for a low Reynold k-epsilon model.
There is also a simple y+ estimator on the web page.
Also, you could use the other calculations to estimate the friction velocity (under the assumption that the other calculations friction velocity is accurate).
The rule y+ around 1 is a guidelines - do not get stuck with it.
k-epsilon model
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 16 March 4, 2017 09:30
k and epsilon Values for High Pressure Water nikhiljain.iitk FLUENT 0 March 12, 2010 07:06
low and high Reynlods numbers amar FLUENT 1 July 23, 2009 12:51
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 21:21
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
