Density Ratio
Old   August 20, 2005, 07:16
Default Density Ratio
Compressibility
hello,
in a high speed compressible flow where there may be shocks forming, what size density ratios might i get?
would these density ratios be bigger than i would get in a low speed combustion system?
thanks
Old   August 20, 2005, 18:29
Default Re: Density Ratio
Jim_Park
Get an aerodynamcis or fluids book from your library, go to the supersonic chapters, and find some of the simple flows that can be solved analytically - with your electronic calculator (or slide rule).
Put some numbers in and calculate the density ratio (also pressure and temperature ratios) across a shock. And you can calculate the shock location. Now you have your answer - and the first test case for your code!
Old   August 21, 2005, 18:24
Compressibility
your answer is not overly helpful for a beginner in the subject ...
Old   August 21, 2005, 19:27
Ahmed
I disagree with you, Jim Park gave you the most correct answer, do your home work and learn the basics
pressure eq. "converges" after few time steps maddalena OpenFOAM Running, Solving & CFD 69 July 21, 2011 08:42
Discrete scheme for VOF method in Large Density Ratio waynezw0618 OpenFOAM Running, Solving & CFD 0 August 11, 2008 10:46
Problem on high density ratio in Level Set method Kai Yan Main CFD Forum 10 December 25, 2007 07:12
REAL GAS UDF brian FLUENT 6 September 11, 2006 09:23
Warning 097- AB Siemens 6 November 15, 2004 05:41
