August 17, 2005, 23:52 |
Airfoil(2d) vs wing(3d) & aspect ratio
I know that for an airfoil, air is not able to flow up and around the wingtip to create trailing vortices, as compared to a finite wing. The amount of difference in cl and cd(?) is dependent on the aspect ratio (AR). However, in practice, below what AR value 'll the difference be unacceptable? Most books just use "large" or "small" with no actual values... thanks |
August 18, 2005, 02:27 |
Re: Airfoil(2d) vs wing(3d) & aspect ratio
Nicolai "Fundamentals of aircraft design", pp 9-12 defines High Aspect ratio wing as one where
AR is greater than 4/(c1+1)/cos(LEsweep angle) where c1 is a function of taper ratio and is given is US DATCOM or Nicolai. I will just list a few number as I read from the figure (there might be some error in reading) c1(taper ratio) 0(0) .25(.1) .5(.2) .4 (.4) .2 (.6) .05 (.8) 0 (1) I hope this helps |
pressure eq. "converges" after few time steps | maddalena | OpenFOAM Running, Solving & CFD | 69 | July 21, 2011 08:42 |
[ICEM] Mesh along axis for a wedge gives elements with extreme aspect ratio | sangrampp | ANSYS Meshing & Geometry | 0 | November 17, 2010 07:57 |
aspect ratio vs. y+ | hammam | CFX | 3 | August 6, 2007 11:41 |
High Aspect Ratio elements | Flavio | CFX | 2 | November 24, 2006 13:01 |
Aspect Ratio at high turbulent and swirled flows | zago | FLUENT | 0 | May 19, 2004 03:37 |
