Typical runtime for simulation with mesh movement?
Old   August 17, 2005, 10:46
Default Typical runtime for simulation with mesh movement?
quarkz
hi,
I've read quite a few papers which simulate wings of insect (3d) or airfoil (2d) flapping. The Re should be 10^3 - 10^4. Does anyone knows what's the typical run time for 1 or 2 cycles, assuming using the university's super computing facilities? Does it need to take months?
thanks alot!
Old   August 22, 2005, 08:13
Default Re: Typical runtime for simulation with mesh movem
Suriyanarayanan
It depends not only on the facilties but also on the procedure that you would be using to compute the unsteady aerodynamics. I am not sure about the 3D case but i am able to get solutions for typical 2D problems in a time of 1-2 hrs.
Suriya
[ICEM] Negative volume error in hybrid mesh siw ANSYS Meshing & Geometry 4 September 3, 2014 06:25
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
engrid -> save as .stl with boundarie codes Zymon enGrid 31 August 29, 2011 14:40
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
