August 16, 2005, 14:00 |
how to set the density in mutiphase flow
Dear all cfders:
I use VOF method to simulate the mutiphase flows (air and water) base on the FEM method. I encountered a difficulty on setting the density. If the ratio of the parameter of air and water is smaller than 1:10, it converges, otherwise, it diverges. But, the actual case is 1:1000. In my procedure, the density is set to RhoA*(1-F)+RhoW*F, RhoA and RhoW are the density of air and water, respectively, and F is the volume fraction. Am i right? Moreover, in the single phase flows, the procedure works well. The model consists of the characteristic method+UZAWA type PCG method+VOF method. The problem is break dam, and all boundaries is slip type. Thanks in advance! Chunning JI |
August 16, 2005, 14:12 |
Re: how to set the density in mutiphase flow
It is typical with high jump coefficient, so look at better solver for that case.
August 16, 2005, 23:21 |
Dear Junseok Kim:
Thank you very much. Can you recommend me a better solver or something about it. In my procedure, a Uzawa type preconditioned conjugated gradient method is adopted. Also, I wondered whether the model for sigle fluid can be transplated to the one for multiphase by only using variable density and viscosity of the fluid. If it is not true, what should be done? Chunning JI |
August 17, 2005, 00:11 |
Dear Junseok Kim:
In the multiphase flow, is the surface tension necessary? If it is omitted, would the result diverges? thanks a lot. Chunning JI |
August 17, 2005, 01:49 |
I am not sure about FEM version, but multigrid preconditioned conjugated gradient method is one good solver for finite difference.
In the free surace, i.e., the density and viscosity of one of phase is negligible, then you can use single phase solver with free boundary condition for pressure solver. See the reference, An investigation of the flow regime rsulting from splashing drops by David Morton, et al. Physics of fluids, vol 12 747-763. |
August 17, 2005, 01:51 |
If the surface tension is important, then it is necessary , but some cases, it is negligible.
Most of cases, surface tension is omitted, the solver is more stable. |
August 17, 2005, 12:33 |
Dear Junseok Kim
Thank you for you advise and I will try it later. In you opinion, the pressure condition p=0 should be set on the free surface. I wonder whether the computational domain above the free surface (i.e., the element with f=0, f is the fraction) is also needed to set p=0. If the pressure of the domain above free surface is settled to zero, whether the velocity is also be enforced to zero? Thank you very much. Chunning JI |
August 17, 2005, 14:05 |
I didn't use one phase simulation, so would you refer reference paeprs?
Problems with the density at walls for a compressible flow | david39 | OpenFOAM Running, Solving & CFD | 0 | February 8, 2010 13:33 |
SIMPLE algorithm for variable density flow | mauz | Main CFD Forum | 1 | May 15, 2009 16:13 |
Negative density problem. compressible flow | Karl | Siemens | 2 | July 10, 2008 17:41 |
Env variable not set | gruber2 | OpenFOAM Installation | 5 | December 30, 2005 05:27 |
Density variation Turbulent flow | Parshant Dhand | FLUENT | 1 | January 17, 2003 00:16 |
