August 16, 2005, 12:30 |
WALL normal velocity
Hi all! I want to set the tranpiration method which consist in setting normal wall velovity different from zero. I use Fluent and the only way I think is to set volumetric sources in a small cell-layer near the wall bc. I don't know how to calculate the source to be added. Do I have to add a mass source besided a momentum and energy ones? How do I calculate the momentum flux? Is this calculated only on the wall boundary or on the cell faces? Please help, I'm very confused. Luca
October 8, 2014, 06:21 |
West Bengal
Hey!!
I am also working on a similar problem, the wall erosion problem in which the species are absorbed and generated at the wall. Were you able to find a way to apply the wall normal velocity? Or how did you solve the transpiration problem? Thanks!! |
Wall Normal Temperature Gradient | Daniel Tanner | FLUENT | 6 | September 20, 2015 14:10 |
Defining normal velocity on walls | mohsen zendehbad | FLUENT | 0 | July 28, 2010 06:51 |
Influece of wall velocity in the main flow | marvin | CFX | 0 | March 22, 2008 03:05 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 21:30 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
