How to import external geormetry into GridPro? |
August 16, 2005, 05:42 |
Dears, I am trying to import geometry from CATIA into GridPro, but I meet some problems. What I did is exporting geometry from CATIA into stl format. Then using chFmt untilities changes stl into GridPro format. And reading the tmp file by surf -> load file, but all my geometry then become into one surface. It is not what I want. Actually I tried several days to import geometry from CATIA into GridPro, and I read all the manual and tutorial, but I have not find the solution about that. Please help me out! Thank you guys!
August 16, 2005, 05:58 |
Re: How to import external geormetry into GridPro?
You can save your geometry into several stl files or split the one surface into different surfaces based on an angle in "minicad".
I use prostar to do the final preparations but thats probably not an option for you |
August 16, 2005, 06:59 |
Thanks, anyway! But, is this the only way to import external geometry into GridPro? For simple case, it is ok! How to deal if the geometry is very complicated?
best regards wang |
August 16, 2005, 07:18 |
There are many way to do this. But what is a "very complicated" geometry for you? An airplane or a car with all details (underhood and engine compartment)?
August 16, 2005, 07:56 |
I can imagine if there are a few surfaces how to manage. But if there are many surfaces, does it take a long time to do that? Probably my question is silly, I do not have any experience about GridPro, just started use it for several days.
Is there any document to describe the detailed procedure to import geometry into Gridpro? I only find very limited information about this in the AZ manual and tutorial document. |
August 16, 2005, 08:52 |
Surface preparation often takes more than 80 percent of the total time for a real world cfd project.
Did you look at the options in "minicad" inside az ? There you can automatically split a big surface based on an angle definition. |
August 16, 2005, 09:13 |
Beilke, Thanks a lot! Actually, I just finished reading about Minicad in AZ manual.
I have to say GridPro is quite different with the program I used before, such as ICEM or Gambit.It takes time for me to get used to it. Also I am exciting about the ability of GridPro to produce high quality structured mesh. I like the way to create grid in GridPro. However, the discussion about GridPro in this forum is much less than I thought. best regards wang |
January 28, 2018, 04:56 |
creating mesh for an imported CAD file
A. Min
Rep Power: 12 |
Hi
I'm beginer in GridPro. I have imported a CAD file to GridPro and now I want to create a mesh. If I want to use mesh tool of gridPro, It creates a mesh only on surfaces, not on body(according to what I can see, maybe I'm wrong!) If I want to make wire frame and create mesh such as the other projects, I can't convert the CAD file to topology file that GridPro can read it. Help me plz!! Thanks |
CGNS Compiling | Diego | Main CFD Forum | 17 | December 21, 2014 02:40 |
Import transient cfx-results for static structural analysis in Ansys WB 13 | Colt Seavers | ANSYS | 1 | August 11, 2011 07:01 |
Import external data into CFX post | Vinod | CFX | 0 | May 15, 2008 07:06 |
Import external mesh data to Ansys-workbench | Steven | CFX | 3 | March 22, 2008 18:40 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 21:30 |
