Grid refinement.
Old   August 15, 2005, 01:18
Default Grid refinement.
Sas
Hi All! I am new to CFD. Would u please tell me some clue about grid refinement. As I need fine grid at some particlular location (in the domain) at any particular time. And after some other time, refined grid is needed at some other location. I heard grid refinment can help. Otherwise simulation on fine grid (whole domain) is wastage of time. Would any one please suggest something. Presently I am using structured grid on cartesian co-ordinates. Thank you in anticipation. Sas.
Old   August 15, 2005, 03:56
Default Re: Grid refinement.
Junseok Kim
Tell us your problem description more detail, for example, you want to solve flow, multiphase flow, heat transfer, crystal growth, etc.
Old   August 15, 2005, 05:02
Sas
For example, the flow of a fluid into another fluid of lesser density. So I need fine grid only at the location where this flow of higher density travles. Other regions (like ambient fluid over this fluid) coarse grid may be used. Am I right in thinking like that. Thanx in advance.
Old   August 15, 2005, 05:08
Junseok Kim
check below site.
http://seesar.lbl.gov/ccse/Software/index.html
Old   August 15, 2005, 06:29
Sas
Thank you very much. there is link " A Conservative Adaptive Projection Method for the Variable Density Incompressible Navier-Stokes equations". I wanted to study that. but that link does not work. It is impossible to open it. What can be done. Please advise. Sas.
Old   August 15, 2005, 12:10
Vinod Dhiman
Hi Chauhan
I have sent that paper at your yahoo ID. Check it.
Vinod Dhiman
Old   August 16, 2005, 03:02
yuan
A tough issue, I guess. Some recent references: 1.Bramkamp,F. et al. 2004. J. Comput. Phys. 197. 2.Mahart,M.,2004. Computers& Fluids 33
Old   August 16, 2005, 03:11
Sas
Thanx Yuan. I will look into this publications. lets us c some things happens.
Old   September 2, 2005, 09:36
Default grid clustering + grid refinement
ashish pande
Respected sir, i need information of above mentioned topic from basics,examples and application etc. with respect to CFD. iam M-tech thermal student of nit,nagpur india thanking u waiting for ur reply
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 04:23
Octree Grid Refinement Tristan CFX 3 September 26, 2008 06:33
Grid Refinement Yamuna FLUENT 0 September 9, 2008 14:24
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 06:59
Grid refinement with wall functions Mark Render Main CFD Forum 8 May 2, 2000 08:09
