Interpolation scheme for structured grids
Old   August 15, 2005, 00:09
Default Interpolation scheme for structured grids
Quarkz
I am now using the interpolation scheme by Kim & Choi (JCP 162 pp411) to evaluate the phi & d(phi)/dn (where phi=u,v,p) at the cell faces for my structured FVM NS code. However, they don't seem to work well. I am not sure if there's some error in my code, although i've checked quite a few times.
Hence, can someone recommend some references of other interpolation schemes for structured grids?
Thank you!
Old   August 15, 2005, 05:30
Default Re: Interpolation scheme for structured grids
ramp
These might be helpfl to you...
[1] Eswaran, V. and Prakash, S. (1998). A finite volume method for Navier-Stokes equations, Proceedings of 3rd Asian CFD Conference, Bangalore, India, Vol. 1, 127-136.
[2] Sharma, A. and Eswaran, V. (2003). A finite volume method, in: Muralidhar, K. and Sundararajan, T. (Eds.), Computational Fluid Flow and Heat Transfer, Narosa Publishing House, New Delhi, pp. 445-482.
Old   August 15, 2005, 05:41
Quarkz
Thanks alot!
However, I am not able to obtain these 2 papers in my library or on the net. Does anyone have them?
Use of upwind scheme for interpolation of u/v quarkz Main CFD Forum 6 August 30, 2011 05:10
On the harmonic interpolation scheme for the diffusivity coefficient vkrastev OpenFOAM 5 April 11, 2011 10:13
solution diverges when linear upwind interpolation scheme is used subash OpenFOAM 0 May 29, 2010 02:23
Momentum Interpolation on Collocated grids Naresh Main CFD Forum 3 November 17, 2009 09:30
CAVITATION (pressure interpolation scheme)!? ROOZBEH FLUENT 0 March 3, 2004 04:26
