Formula for velocity in buffer layer of turbulent boundary layer
Old   February 3, 2012, 12:57
Default Formula for velocity in buffer layer of turbulent boundary layer
Nikolay Vinnichenko
nickvinn is on a distinguished road
Hello!
I was calculating turbulent viscosity according to Baldwin-Lomax model for the fixed velocity field of flat plate turbulent boundary layer and had problems with too low viscosity in the outer layer of the model. Now I realize that the velocity profile by Reihardt u^+=ln(1+\kappa y^+)/\kappa+7.8*(1-exp(-y^+/11)-y^+*exp(-y^+/3)/11), which I was using, yields bad F-function with peak located too close to the wall. I changed for piecewise u^+=piecewise(y^+<5, y^+, y^+<30, 5*ln(y^+)-3.05, ln(y^+)/\kappa+5.5). It yields F-function with correct global maximum. However, du^+/dy^+ is discontinuous, so another local maximum exists closer to the wall. I'm afraid that for some values of parameters I can take it for the right one. Is there any analytical expression for velocity profile with correct description of buffer layer (5<y^+<30) and continuous derivative?
nickvinn is offline   Reply With Quote
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
[GAMBIT] 3D boundary layer and meshing problem in GAMBIT 2.4.6 prashanthreddyh ANSYS Meshing & Geometry 1 December 20, 2011 01:35
Turbulent boundary layer resolution deji OpenFOAM 2 June 15, 2011 14:57
Turbulent Boundary Layer Reference Erika Johnson FLUENT 2 January 27, 2006 10:10
Boundary Layer Meshing of a nosecone Chris FLUENT 1 March 15, 2005 13:42
