Software that can stretch the overall dimensions of a mesh.
Old   January 27, 2012, 06:34
Default Software that can stretch the overall dimensions of a mesh.
Robert
Robert_B is on a distinguished road
Hi all
I am trying to find a way to stretch my mesh dimensions by small amounts in various directions.
I am modelling a pulsejet, with shape similar to this one:
http://www.google.co.uk/imgres?q=cal...t:429,r:4,s:54
I have built an unstructured tetrahedral mesh, and it seems to modelling the pulsejet's operation well.
I now want to make small alterations to the pulsejet's dimensions, and examine the effect of these alterations on its performance. So for example, I would like to alter the length of the inlet pipe by 5% (say), while leaving all other dimensions unchanged.
I want to make these alterations, without having to build a new tetrahedral mesh from scratch. Rather I want to take my existing mesh, and stretch or compress various parts of it, to achieve the desired alteration in dimensions. The number of cells and their relative positions should remain unchanged.
The program I am using is StarCD, but it does not seem to have a facility for stretching sections of mesh. So I would like to know if there is a good program that I could use to stretch sections of my mesh?
I can export my mesh in the following formats: Ansys, Nastran, ICEM, STL, Patran, Ideas, pro-STAR. Hopefully there will be a program that can take a mesh saved in one of these formats, and perform the desired stretching operations. I could then import the altered mesh back into StarCD.
Can anyone help by recommending a program that can perform the stretching operations I have described?
Robert_B is offline   Reply With Quote
Old   January 27, 2012, 08:00
sail's Avatar
Vieri Abolaffio
sail is on a distinguished road
Originally Posted by Robert_B View Post
Hi all
i don't think you can simply strech a mesh.
what i would reccomand would be to create the mesh and the geometry with a script-able software. in this way you can recreate the mesh with the modified geometry with just a couple of clicks/commands.
most of softwares can do this, pointwise, gambit, icem are just the first that comes to mind.
of course this make sense if you have to run lot of simulations with differences in the geometry. in case of a sinle run with just a 5% inlet lenght, you might try some workaround like using interfaces, and so on. If it is the case, i'm afraid i can't help you because i'm not proficent with starCd.
good luck.
http://www.leadingedge.it/
Naval architecture and CFD consultancy
sail is offline   Reply With Quote
Old   January 27, 2012, 08:39
Joern Beilke
JBeilke is on a distinguished road
StarCD can definately do what you want. Have a look at the vscale command.
JBeilke is offline   Reply With Quote
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 07:41
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 12:45
Mesh generation software is needed H.Dou Main CFD Forum 12 May 4, 2011 16:20
CFX mesh cause software blocked ahlo CFX 3 December 13, 2007 14:34
