Finite volume methods, reconstruction, etc.
Old   January 23, 2012, 12:08
Default Finite volume methods, reconstruction, etc.
Nereus
Nereus is on a distinguished road
Hi:
I have a question about finite volume methods, specifically regarding the calculation of fluxes at control volume faces. The books I have read devote a lot of time to discuss the reconstruction of scalar variable U at these faces. For example, the reconstruction of U_{i+1/2}. Then, it is usually stated that we can calculate the flux, F_{i+1/2}=F(U_{i+1/2}), and everything is peachy. I understand the reconstruction of U_{i+1/2}, but what confuses me is if, for instance, I'm considering an advective flux, what velocity do I use with the reconstructed variable at i+1/2 to get my flux? A simple average velocity at the control face?
In short, do I also have to go through the reconstruction process that I used for the scalar variable for the velocity vector?
Nereus is offline   Reply With Quote
Old   January 24, 2012, 10:40
Nereus
I suppose all I'm really asking is, if I know the velocity field at the nodes how do I interpolate to achieve velocities at control volume faces (using a median-dual scheme)?
Old   January 24, 2012, 13:12
duri
duri is on a distinguished road
I suppose U is conservative/primitive variable. Once you got it for all equation it is easy to estimate variables needed at face.
duri is offline   Reply With Quote
Old   January 24, 2012, 15:31
Nereus
But, how? Say, for example, U is some tracer concentration and I know the velocity field at all nodes. How do I then determine the velocity field at the face of the control volume? As I say, there's a lot of literature on reconstructing U (i.e., scalar conservative variables), but no word on the velocity field.
Old   January 25, 2012, 01:53
duri
When you are solving let say 2D Euler, reconstruct r,ru,rv (r-density) at the face like a scalar variable. Once you got this you can get u and v at face by ru/r and rv/r. Its straight forward.
Old   January 25, 2012, 02:46
Nereus
Thanks for the replies, duri. I'm not actually solving CFD (i.e., Euler or Navier-Stokes) equations, but just general conservation law equations using finite volume methods. So, I prescribe a velocity field onto the grid, I just don't know the best way to interpolate this field to my control volume faces. Would simple linear interpolation along edges work? Or do standard methods like MUSCL work for vectors like velocity fields, too? I realise that this may seem like a trivial point to those in the know, but I'm at a loss to figure out the best way to achieve this.
Old   January 31, 2012, 12:31
leflix is on a distinguished road
Hi Nereus,
Let's imagine you want to solve a transport equation for a scalar phi. This variable is convected by U velocity. When integrating over a control volume the convection term div(Uphi) where div is the divergence operator you will have to express U and phi on all control volume faces. let's say at i+1/2.
Generally U at i+1/2 is expressed using a simple interpolation function. For example if your grid is regular you could use Ue=(UP+UE)/2 "e" stands for the location i+1/2
For phi variable you have to choose a discretization scheme. There exist a tons of such schemes (CDS, UDS, Hybrid, Power-Law, TVD schemes, ENO, WENO , blended schemes....) there are really a big choice according the type of your transport equation (dominated convection equation, Hyperbolic equation,...)
You have to distinguish the scheme used for phi and the one for U. If phi=U then you may have two different schemes.
leflix is offline   Reply With Quote
Old   January 31, 2012, 12:40
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
answering to your question depends on what you are solving, compressible or incompressible flows... in the first case I suggest the book of LeVeque on FV method for hyperbolic systems, in the second case the book of Ferziger and Peric is useful for addressing the flux interpolation issue.
Do not forget that the colocation of the variables can be staggered or non-staggered.
FMDenaro is offline   Reply With Quote
Old   January 31, 2012, 16:51
Nereus
Thanks, leflix, that's exactly what I was after. I reconstruct my scalar variable using Barth & Jespersen's linear piecewise reconstruction and calculate the flux using Kurganov & Tadmor's scheme, I just needed to know what the velocity was at the faces. I'll use a simple interpolation, as you suggest.
Thanks for the reply, Filippo. I'm not solving a fluids problem as such, but rather a general conservation equation.
Old   January 31, 2012, 17:12
if you are involved only on a formal reconstruction problem for conservation laws, perhaps you can do best by using spectral polynomials
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
Finite Difference Vs. Finite Volume elankov Main CFD Forum 43 December 18, 2010 17:30
Finite Volume WENO Scheme DSS Main CFD Forum 3 January 15, 2007 04:47
Finite volume or finite differene for free surface G N Xie Main CFD Forum 8 January 10, 2005 08:42
Unstructured grid finite volume methods Marcus Main CFD Forum 3 December 5, 2000 01:25
