Unknown Difference Scheme
Old   August 1, 2005, 09:46
Default Unknown Difference Scheme
Jan Christian Dittmer
Hallo!
I try to analyse a numerical program and found an unknown difference scheme to interpolate the value between point x_0 and x_1.
(u_{1/2})= [5 (u_0) + 8 (u_1) - (u_2)] /12h
(u_{1/2})= [-(u_-2) + 13 (u_-1) + 13 (u_0) - (u_+1)] /24h
(u_{1/2})= [-(u_-2) + 8 (u_-1) + 5 (u_0)] /12h
Point x_-2, x_-1, x_0, x_1 and x_2 are equidistant of distant h.
Can anybody tell me, how to derive this scheme?
Thank you!
jc
Old   August 1, 2005, 14:30
Default Re: Unknown Difference Scheme
Junseok Kim
I guess it is dervied from second order polynomial for first and third approximation and third order polynomial for the second approximation.
Old   August 2, 2005, 05:34
I tried to figure out but I came to result that in case the formulars are derived from polynomials the coefficients shouldn't be independent of the u values, should they? So to me it seems not to be the polynomial approch.
JC
Old   August 2, 2005, 05:47
Junseok Kim
You are right, by the way, where did you get those difference schemes?
Old   August 2, 2005, 06:07
A former colleague wrote a C program for droplet combustion. And I (2 generations later) shall extend this program without anyone who knows exactly what's going on.
JC
Old   August 2, 2005, 06:46
Junseok Kim
(u_{1/2})= [5 (u_0) + 8 (u_1) - (u_2)] /12h seems missing something because if u_0, u_1, u_2 are constant, say, u, then u_{1/2} = u/h ?
Old   August 2, 2005, 06:55
You are right here ;-) In my program h=1.
JC
Old   August 2, 2005, 23:28
Ahmed
May I suggest that you read the book by Clive Fletcher Computational Techniques for fluid Dynamics, Volume 1, chapter 3 and especially 3.2.2 the general Technique for developing approximation to derivatives. You can also check the book by J.C.Tannehill, Anderson and Pletcher Computational Fluid Mechanics and Heat Transfer. Normally mid point values are needed when developing Quadratic interpolations like the Quick Scheme. The important point to remembere here is to use the correct order of polynomials for developing your scheme.
Old   August 9, 2005, 04:36
That you very much! The book of Fletcher seems to give me the right answer.
The mentioned sheme seems to be a combination of 4th and 2nd order mean value in the center and 3rd and 2nd order at the edge. Weight for 4th and 3rd order respectively is 2/3 and 1/3 for the 2nd order approximation:
4th order scheme: (-1, 9, 9, -1)/16 2nd order scheme: (0, 1/2, 1/2, 0) leads to (2/3*4th Order + 1/3*2nd Order) (-1, 13, 13, -1)/24
3rd order scheme: (3, 6, -1)/8 2nd order scheme: (1/2, 1/2, 0) leads to (5, 8, -1)/12
Thanks again!
Christian
[Commercial meshers] fluent3DMeshToFoam bego OpenFOAM Meshing & Mesh Conversion 31 August 16, 2023 10:04
dsmcInitialise - dsmcFoam archymedes OpenFOAM Pre-Processing 94 July 15, 2016 17:14
High order difference scheme for KIVA3v2??? LiQiang Main CFD Forum 1 May 9, 2005 14:50
Difference scheme for ALE ?? LiQiang Main CFD Forum 0 March 26, 2005 22:17
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
