prove DNS results
Old   July 29, 2005, 08:22
Default prove DNS results
dirk
How can i prove, that a DNS was correctly done. I found the following by searching this forum:
"The usual test for a fully valid DNS simulation is to check that no energy is aliasing back from the highest resolvable wavenumbers and distorting the low wavenumbers. This is a nice simple mathematical test equivalent to saying that the Kolmogorov scales (all the scales) are fully resolved."
I must confess, I am a CFD beginner. So maybe there is an easier to understand answer.
Thanks, Dirk
Old   July 29, 2005, 10:31
Default Re: prove DNS results
tom
For several flow geometries (channel flow, isotropic turbulence etc.) there exits rules of thumb for the spatial resolutions. These you can find in the literature. But the spatial resolution is not the only important issue in DNS. Boundary and initial conditions and the domain size (the domain should be large enough to capture the largest scales) play also a crucial role.
Eckardt Impeller (1980) test results. Andrew de Wet Main CFD Forum 7 July 8, 2017 03:57
How to plot a function over a time period? Cirion0000 CFX 4 July 18, 2009 13:48
Airfoil y+ Results Query asd Main CFD Forum 1 June 22, 2007 09:02
Problems with repeating results Lee Siemens 4 May 26, 2006 04:39
Circular miniFlume experimental amp numerical results amelia OpenFOAM Running, Solving & CFD 11 September 4, 2005 23:42
