Applying boundary conditions to 1D Steady Convection Diffusion using Power Law Scheme
Old   January 5, 2012, 20:47
Post Applying boundary conditions to 1D Steady Convection Diffusion using Power Law Scheme
ConvDiff is on a distinguished road
I am currently trying to solve the convection diffusion problem for Phip(centre of node) utilising the power law scheme but have come unstuck in determining the co-efficients(ae, aw, Su, Sp) at the boundaries i.e the first and last nodes. The form utilised is following the Versteeg CFD Textbook 1995, and the co-efficients are given for only the central nodes:
ap*Phip=ae*Phie+aw*Phiw+Su
ap=aw+ae-Sp
For instance for the central differencing scheme at the 1st node:
aw=0, ae=D-F/2, Sp=-(2D+F), Su=(2D+F)*Phi0.
Where D=DiffusionCoeff/dx and F=rho*u
I have written a TDMA solver in matlab that is currently working for the central differencing, upwind and hybrid schemes, this is the last one and I'm losing my mind!
Any help would be greatly appreciated! Regards Rastaman
ConvDiff is offline   Reply With Quote
Old   January 7, 2012, 17:40
leflix is on a distinguished road
ap=aw+ae-Sp
Once you have been able to compute all the coefficients for every nodes (I mean AP, AW, AE and SU) if your TDMA solver works for the other schemes (central, upwind and hybrid) it should work as well with powerlaw scheme.
Another point is that the BC do not depend on the discretizing scheme at least only on the way to implement them.
If the scheme you use is based on 3 points, W, P and E at most, the way you have implemented the BC for central or upwind will not change for powerlaw.
The scheme which is used only change the coefficients. That"s all.
What you have done according Versteeg seems correct..
Jah guide !
leflix is offline   Reply With Quote
Applying two different boundary conditions on same region shahpar73 CFX 1 October 4, 2010 19:06
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 07:18
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 20:23
grid manipulation and applying boundary conditions Chetan Kadakia FLUENT 3 August 22, 2000 05:51
