July 24, 2005, 22:01 |
Thermcouple Reading
Any one have ideas on why when fan speed is increased the thermcouple shows a lower temperature reading. Can in duct can show temperature lower than ambient. I thought no but the folks ad Omega say it's possible due to colling effect!!!. Appreciate any references to this so called cooling effect. Thanks in advance.
July 24, 2005, 22:44 |
Re: Thermcouple Reading
At first sight what you are saying is not but If thermodynamic inversion takes place, then it is possible (check Joule-Thompson effect in your thermodynamics book) then check your geometry and where the thermocouple is located with respect to the velocity field, and plot the enthalpy field.
[Commercial meshers] Problem converting fluent mesh | vinz | OpenFOAM Meshing & Mesh Conversion | 28 | October 12, 2015 07:37 |
Cht tutorial in 15 | braennstroem | OpenFOAM Running, Solving & CFD | 197 | June 10, 2015 04:02 |
Problem in running ICEM grid in Openfoam | Tarak | OpenFOAM | 6 | September 9, 2011 18:51 |
[Commercial meshers] Converting a mesh with splitted cells using fluentMeshToFoam | jlpelerin | OpenFOAM Meshing & Mesh Conversion | 4 | April 25, 2011 17:56 |
problem when converting mesh (made by ICEM) using fluentMeshToFoam | Forrest_Lei | OpenFOAM | 11 | October 16, 2009 07:28 |
