December 27, 2011, 02:28 |
minimum force to start a motion
s Kumar
Rep Power: 16 |
Hello everyone,
I have a 2D elliptical solid in rectangular fluid domain. I want to know what is the minimum horizontal force required to start off the horizontal motion. The fluid is highly viscous. Reynodls number is very low. Stokes law is applicable. Any idea, how to find the minimum force? Thanks in advance Doctsh Last edited by doctsh; December 27, 2011 at 02:46. |
December 29, 2011, 02:00 |
cfdkid
Rep Power: 17 |
Is object suspended in the fluid i.e are the vertical forces balanced? |
December 29, 2011, 02:42 |
s Kumar
Rep Power: 16 |
Hi. thanks for the reply. It is immersed inside fluid and free to move. I want to know how much minimum force I have to apply horizontally so that it can start moving horizontally. vertically no force is acting on it. weight and other inertial forces are negligble.
December 29, 2011, 03:07 |
cfdkid
Rep Power: 17 |
Consider your object to be freely suspended i.e vertical forces are balanced , and the fluid is stationary.
Now, whatever Re you take if at all the fluid moves or has velocity in any given direction Then the object must move. Now , how would you answer " what is F for moving the object?". Any bare minimum force is enough, i suppose. Given i understood your Boundary conditions properly. But if you plan to move object against the flow direction, then "the F required will have to be greater then Drag Force". Regards, Kid Last edited by kid; December 29, 2011 at 03:31. Reason: there can be two cases as problem discription was not self explaintry. |
December 29, 2011, 03:58 |
s Kumar
Rep Power: 16 |
Yes. I got the answer from you.
My problem is little deeper. This is where I am confused. Ok I will explain my problem. I have an ellipse solid in stationary fluid. It keeps oscillating up down (prescribed moving wall BC). Due to this there is thrust generated laterally. I want to know how much lateral force is required to initiate horizontal motion through vertical flapping motion. The outer BC for fluid is to denote infinite extent. Last edited by doctsh; December 29, 2011 at 04:20. |
December 29, 2011, 05:17 |
cfdkid
Rep Power: 17 |
kumar,
Suppose you solve this problem for n number of oscillation i.e accordingly you need to check time for run. Now we require to calculate drag coefficient i.e drag force on your object. and also conduct another simulation for steady state calculate and its drag coefficient and drag force. Use this data to match from simulation one and find out where it matches or becomes grater then the steady state drag force. That should be the minimum force required to move object in either direction. Would like to know your comment and suggestions. Regards, kid |
December 29, 2011, 05:25 |
s Kumar
Rep Power: 16 |
OMG
This is what I wanted. I am doing that. you are not cfd'kid', you are cfd'expert' |
Force and Force Coefficient | ata | OpenFOAM Post-Processing | 9 | August 18, 2021 13:44 |
User-defined force transfer across FSI interface | vivekcfd | CFX | 7 | March 10, 2010 20:43 |
DEFINE_CG_MOTION and pressure force | Teo Fumagalli | FLUENT | 0 | April 11, 2008 10:25 |
tank motion on boat | Tim | FLUENT | 0 | May 23, 2007 11:50 |
large scale mesh motion | sb | FLUENT | 1 | April 27, 2007 22:23 |
