Problem with results of simulation of flow past sphere at Re=250 |
December 23, 2011, 17:14 |
TWB
Rep Power: 19 |
I'm trying to simulate flow past sphere at Re=250. From the literature, it seems that at this Re, the flow is no longer axial symmetrical, but a plane of symmetry still exists. Besides a non-zero drag force (cx), there is also an additional force in the non-symmetrical flow direction (cy). The force in cz is zero, since it's still symmetrical. When I try to simulate it, I got a similar cx value, but my flow is no longer symmetrical in all direction. My cy and cz are also almost the same value. I tried to refine my grid but there is no difference. Does anyone has experience in this before? What could have gone wrong? |
December 29, 2011, 03:24 |
hi
cfdkid
Rep Power: 17 |
Can you look into paper again, as it seems as if the object is cylinder and not a sphere? ( though the side view for both would be same)
Regards kid |
December 30, 2011, 07:31 |
TWB
Rep Power: 19 |
Thanks Kid but I think I got the ans - I need to look the diagonal y and z. from that view, it is symmetrical
good Cold Flow Results but problem with Hot Flow | Rams | FLUENT | 1 | June 18, 2006 20:59 |
good Cold Flow Results but problem with Hot Flow | Rams | CFX | 2 | June 13, 2006 04:30 |
flow past sphere: surface pressure distribution | roland schmehl | Main CFD Forum | 3 | August 21, 2001 14:29 |
boudary conditions for flow past a sphere | srijit goswami | Main CFD Forum | 3 | January 27, 2001 08:28 |
Simulation of Two Phase Fluid Flow Problem Using Fluent 5.0 | Mohammad Al-Shannag | Main CFD Forum | 1 | July 16, 1999 12:28 |
