deformation
Old   July 20, 2005, 09:49
Default deformation
Dominik
Hi all, I want to model deformation of an elastic sack filled with water. I apply normal pressure at given boundary sections and I want to get back normal pressure everywhere else, so I can deform the interface in a separate step - and repeat the iterations. Can someone sketch a rough modeling approach to get the wall pressures in such a case? I know how to deform the interface once I have these values. Thanks a lot. Dominik
Old   July 20, 2005, 20:14
Default Re: deformation
Mani
Given the pressure on the sack that you apply from outside, and the pressure that your CFD solver spits out on the inside, determine the new deformation and cycle back. Which part are you unsure about? How to obtain the flow solution?
If this is an unsteady problem you'll need to do CFD, if it's quasi-steady or steady, you can treat it as a hydrostatics problem. It the latter case it has nothing to do with CFD.
Deformation Issues... Silmaril CFX 5 April 26, 2011 14:24
CFX Mesh Deformation problem Silmaril CFX 7 October 19, 2010 11:00
Calculation of the deformation rate titio OpenFOAM Running, Solving & CFD 1 March 22, 2009 09:45
Predefined Mesh Deformation Alexv CFX 6 October 6, 2008 13:01
Mesh Deformation Problem Virag Mishra CFX 0 October 9, 2007 01:37
