residual in the pressure correction
Old   July 18, 2005, 09:54
Default residual in the pressure correction
George
Hi all! I am facing a problem of convergence in the pressure correction equation.The code that I am writing is about compressible viscous unsteady turbulent flow.The residual of the pressure correction is of the order of 0.001 and it never becomes less.I think the thing that I am not doing correct is the implementation of the boundary conditions.Can you please describe me with detail what they should be? (Ap*P'=SUM(Ai*Pi)+Su). The cell next to the wall has: Ai=0.0 and on the inlet and outlet is again: Aw=0.0 and Ae=0.0.
I hope there is someone out there that can help me.
Thank you in advance!
Old   July 21, 2005, 22:25
Default Re: residual in the pressure correction
yuan
First contour the L1-norm of pressure coreection to see where are the locations of the maxima, then the next step. All those Ai equal to 0 at both the inlet and outlet imply both pressure values fixed. That is wrong, I guess.
Old   July 28, 2005, 05:43
George
Sorry for being late, but I was on holidays these days. Yes, I specify pressure at both inlet and outlet. Because the velocity is not that high (around 20-30 m/sec), I specify static pressure there. My question was if I should add some more boundary conditions next to the walls and at inlet-outlet. Thank you!
Darcy-Forchheimer law for specifying Porous Zones Ger_US OpenFOAM Running, Solving & CFD 37 April 10, 2022 04:38
Compressible Nozzle Flow sebastian OpenFOAM Running, Solving & CFD 14 September 21, 2016 11:47
ForcesCoeffs ronaldo OpenFOAM 4 September 14, 2009 08:11
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
Modeling in micron scale using icoFoam m9819348 OpenFOAM Running, Solving & CFD 7 October 27, 2007 01:36
