Finite Volume Method in Java with GPU support
Old   December 14, 2011, 11:43
Default Finite Volume Method in Java with GPU support
Felix Apel
Don456 is on a distinguished road
I'm working on a program in Java to solver the navies-stokes equation in two dimensions using finite volumes with the simple algorithm. I use lid-driven-cavity as a test case.
I have implemented the linear equation system solvers in Cuda and also in Java and solved one dimensional temp transport problems with it.
So far solving the momentum equation is not a problem and seems to work fine.
But the pressure correction is broken, the values for the pressure correction get bigger after each time step until nan values appear.
Since this is part of my Master Thesis, I checked back with my professor and he told me to use a pressure reference.
Has somebody an idea how this is implemented?
Greetings Felix
Don456 is offline   Reply With Quote
Finite Volume Method For Cylindrical Coordinates falopsy Main CFD Forum 45 August 14, 2023 22:14
Chorin's Projection Method for Finite Volume Scott2 Main CFD Forum 1 August 16, 2010 21:24
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
Finite volume method vs finite difference method? superfool Main CFD Forum 4 October 21, 2006 15:37
ALE in finite volume method littlelz Main CFD Forum 5 June 21, 2003 13:50
