FFT requires capacity which is larger than the maximum computer capacity
Old   December 8, 2011, 10:17
Default FFT requires capacity which is larger than the maximum computer capacity
non
tewyme is on a distinguished road
I encountered this error, when I tried to do the FFT in x direction for a 3D array, I think this is because howmany=2359296 is larger than the maximum capacity for a 32 byte computer (2^31), so I am eager for any potential resolution for this, thanks a lot
File "./change_energy_spectra.py", line 46, in egy_spe
arr_F=rfft(arr,nx,-1)
File "/usr/lib64/python2.7/site-packages/scipy/fftpack/basic.py", line 201, in rfft
return _raw_fft(tmp,n,axis,1,overwrite_x,work_function)
File "/usr/lib64/python2.7/site-packages/scipy/fftpack/basic.py", line 49, in _raw_fft
r = work_function(x,n,direction,overwrite_x=overwrite_ x)
_fftpack.error: (n*howmany==size(x)) failed for hidden howmany: drfft:howmany=2359296
tewyme is offline   Reply With Quote
Old   December 12, 2011, 14:37
cfdnewbie
cfdnewbie is on a distinguished road
I'm no expert in this, but it looks like you are linking 64bit libs, so I assume you have a 64bit system?!
Did you check your memory requirement during runtime?
cfdnewbie is offline   Reply With Quote
fft
