December 7, 2011, 03:08 |
Unsteady flow - tank drain (please help)
Danny
Hello Everyone,
For the last 2 weeks I have tried to model an unsteady flow with no viable results. Problem description: Create a 10 meter in diameter cylindrical tank with an outlet nozzle of 1 meter in diameter. How long does it take the fluid level to drop from 30meter above the tank outlet to 1 meter above the tank outlet? The top of the tank is open to the atmosphere. I have done the following: - Created geometry in GAMBIT. (30m height, 10m diameter, w/nozzle 1m above bottom) - Once in FLUENT: Define/Models/Solver/Unsteady Define/Models/Viscous/k-epsilon Define/Operating Conditions/ -Pressure set at 101325 Pa - Gravity check marked Define/Boundary Conditions/ - Open top of cylinder: Vent Inlet @ 0 psig - Nozzle exit: 1 flow rate Solve/Monitors/Residuals -All checked marked (1x10^-5) Solve/Monitors/Statistics -Time and delta time: print Solve/Initialize/Initialize - No initial conditions since at time zero draining has not begun. Solve/Iterate - NOT SURE WHAT TO DO HERE! PLEASE HELP!!! I am worn out from trying everything possible! (except the right approach) |
unsteady flow |
Airfoil conditions for unsteady flow | Dave | Main CFD Forum | 3 | April 24, 2008 18:11 |
Unsteady flow structures - time development | diaw | Main CFD Forum | 4 | December 13, 2005 06:15 |
Unsteady Flow in FLUENT | Vidya Raja | FLUENT | 0 | November 1, 2005 18:54 |
Solving unsteady compressible low speed flow | atit | Main CFD Forum | 8 | July 31, 2000 14:19 |
computation about flow around a yawed cone | Tylor Xie | Main CFD Forum | 0 | June 9, 1999 08:33 |
