stream function & vorticity boundary condition |
December 4, 2011, 11:45 |
sara
HI everyone.
I've wrote a code to simulate velocity field over a square cylinder. I've used vorticity-stream function solver at 0 angle of attack.(not immersed) but now I don't know how to specify outflow boundary condition for different angles of attack. I used a rectangular as my domain. please help me. thank you for reading my thread. |
December 5, 2011, 09:10 |
Andrew
Rep Power: 18 |
I did this for a finite difference method (except I did flow over a step). My exit boundary condition was @x=L, Streamfunction(@x=L) = Streamfunction(@x=L-1). I did this based on assuming that the flow after the step was fully developed and not changing. My vorticity BC was the same. The results were good.
December 6, 2011, 10:53 |
#3 | |
sara
but in my case I have vortex shedding which makes it more complicated. By the way, did free stream velocity have an angle of attack in your case? or it was simply horizontal? |
December 6, 2011, 11:08 |
Andrew
Rep Power: 18 |
it had no angle of attack, but why can't you extend the rectangular grid long enough to where the vortex shedding has dissipated and the flow is fully developed?
December 7, 2011, 17:42 |
#5 | |
sara
Well, I did so. but still there are lot's of problems. for example, even if the flow behind the cylinder is fully developed, it still has its angle of attack, so I can't impose the boundary condition you used for outflow. there are other difficulties in dealing with far field boundaries. thank you for your reply. |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
vorticity stream function method | ztdep | Main CFD Forum | 0 | April 15, 2010 10:17 |
How to apply a function as boundary condition | coompressor | OpenFOAM Running, Solving & CFD | 0 | January 13, 2009 03:50 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
