July 12, 2005, 14:19 |
analysis of wind turbine blades
i've a doubt regarding analysis of wind turbine blades in fluent, do we need to model the blade with the twist or it should be straight to get same AOA over the whole span,which one is correct, i'm using periodic boundaries on either side ,inlet, outlet and a wall on top, do we need to give rotating reference. thanx in advance sharukdear@gmail.com
July 16, 2005, 14:14 |
Re: analysis of wind turbine blades
Just think about it: Assuming uniform wind velocity, the incoming axial velocity component is independent of the radius. However, the circumferential component of the relative velocity varies linearly in span direction, because of rotation.
There is no way to get the same AOA over the whole span on a straight blade. >i'm using periodic boundaries on either side ,inlet, utlet and a wall on top What do you mean by 'top' ?? |
July 16, 2005, 15:40 |
i'm using wall condition insted of farfield, is it correct, i was not getting through the periodic boundary condition so i've meshed for full model, how can i get the rotational velocity of the rotor in fluent, the blade section at tip will be a bluff body initially, so, how much rps i've to give, is it relative or absolute rotating frame, thank u
April 24, 2009, 06:23 |
Windrotor simulation in cfd
Hi, everyone: Can I use the Turbogrid to mesh the flow field of a wind turbine blade? I know the Turbogrid and ICEM can mesh an internal flow turbomachine easily such as gas turbine and water turbine. But I'm not sure whether it can mesh an external flow rotor like wind turbine. Does anyone has some experience and give me some advice? Thank you!
sivaramakrihnaiah |
June 22, 2009, 07:45 |
3Dwind turbine rotor_cfx-11_error
Hi all,
FATAL ERROR : | | | | Initial values are required for all variables in TRANSIENT runs. | | In this simulation, no initial value was set for | | | | Variable : Pressure | | Domain : rotordisc | | | | The value can be set using the Initial Values panel in CFX Pre. | | | | To bypass this message and use default solver initial values, | | set the expert parameter "transient initialisation override = t"
sivaramakrihnaiah |
April 20, 2010, 06:20 |
power out put
#6 | |
yashwant
Rep Power: 16 |
April 20, 2010, 06:25 |
wind turbine blade
Hi
In Turbogrid software willl use onlt internal flow problam, actually wind turbine blade External flow problem. Here there is no domain, My skype Id:sivaramakrishnaiah1 MY google talk ID:malayathisiva@gmail.com
sivaramakrihnaiah |
December 9, 2014, 19:59 |
who can i calculate the power of wind turbine blade at different AOA
zahid
Rep Power: 12 |
how can i calculate the power of wind turbine blade at different AOA
plz hlp me |
Wind Turbine Analysis Suggestion | andrea.pasquali | OpenFOAM | 13 | March 25, 2015 06:27 |
FSI - Wind Turbine | AUN | CFX | 13 | August 29, 2012 17:44 |
CFX Analysis of a wind turbine | Bournegenius | CFX | 16 | August 20, 2012 20:16 |
Analyses and Design of Wind Turbine Blades, please help!!! | heavymag | Main CFD Forum | 7 | April 13, 2012 17:51 |
Usage of Star-CD in analysis of Wind Turbine | Manabendra M. De | Siemens | 5 | January 7, 2007 00:42 |
