wall function method
Old   July 12, 2005, 14:08
Default wall function method
Elaprolu vishnuvardhanarao
I have developed code for k-e model and it is applied for square lid driven cavity for Re=480000. it is working well, and when it is for rectangular cavity with x:y 1:3, it is not giving good results. I will be thankful if can anybody suggest me regarding this.
Old   July 20, 2005, 03:55
Default Re: wall function method
yuan
Some instability of the large-scale flow may develop. In this case your RANS method may become too inaccurate. Even in the square case, the small-scales of corner flow calculated seems OK?
Old   July 20, 2005, 17:31
Does any alternative is there to overcome this...
Old   July 21, 2005, 21:54
yuan
I am not quite sure how to improve a RANS scheme, add more Numerical Viscosity to suppress those instabilities or reduce NV to model. A more accurate model may work, but that type of instability is more subtle and probably inherent in the flow itself.
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 01:35
Question about wall function Gary Main CFD Forum 1 December 3, 2007 11:54
Droplet Evaporation Christian Main CFD Forum 2 February 27, 2007 07:27
SST model Autometic wall function parameters? David CFX 0 November 24, 2005 05:47
Novel wall function method --? LS Frinch Main CFD Forum 7 July 19, 2001 11:18
