Green's theorem or divergence theorem?
Old   November 30, 2011, 17:11
Default Green's theorem or divergence theorem?
Hermano is on a distinguished road
I want to calculate the total flux but I'm not sure if I have to use Green's theorem (2D) or the divergence theorem (3D). The equation below is a modified Reynolds equation describing the air flow in the clearance of porous air bearing.
\frac{\partial}{\partial\theta}(PH^3 \frac{\partial P}{\partial\theta}) +(\frac{R}{L})^2 \frac{\partial}{\partial Y}(PH^3 \frac{\partial P}{\partial Y}) - \Lambda \frac{\partial}{\partial\theta}PH + \Psi P (\frac{\partial P'}{\partial Z})_{Z=1} = 0
P is the pressure in the clearance of the air bearing, P' is the pressure in the porous media. However, at Z=1 P' must be equal to P for continuity.
This equation can be rewritten using the divergence vector operation:
\nabla\bullet\left[PH^3 \frac{\partial P}{\partial\theta} + (\frac{R}{L})^2 PH^3 \frac{\partial P}{\partial Y} - \Lambda PH + \Psi P P'\right] = 0
Solving this equation with a numerical method (i.e. finite difference) can be done by first simplifying the equation with Green's theorem for flux or the divergence theorem. Because I'm interested in the flow in the \theta - Y direction I want to solve the equation applying Green's theorem (2D). However, in the first equation there is also a gradient in the Z-direction namely \Psi P (\frac{\partial P'}{\partial Z})_{Z=1}. So my question is: Can I calculate the flux with Green's theorem or do I have to use the divergence theorem because of the pressure gradient in the Z-direction?
Hermano is offline   Reply With Quote
UDF divergence of a vector cris FLUENT 3 September 4, 2014 19:06
Divergence problem for species transport model MY FLUENT 3 January 11, 2014 05:46
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 12:34
Divergence theorem in cylinderical coordinates peter.zhao Main CFD Forum 3 October 11, 2004 09:54
divergence in MAC Method Maciej Matyka Main CFD Forum 2 December 19, 2000 11:43
