moving boudnary pressue condition
Old   July 11, 2005, 06:42
Default moving boudnary pressue condition
zx
Does anyone know how to specify pressue (pressure correction) BC for incompressible flow on a moving boudary (esp. where the acceleration is not zero)? Is dp/dn = 0 correct? or should it be dp/dn = -an (an is the boundary acceleration in the normal direction of the moving boundary)? Thanks a lot.
Old   July 11, 2005, 09:35
Default Re: moving boudnary pressue condition
Jim_Park
The correct condition is the physical one, velocity of the fluid at boundary equals the velocity of the boundary.
How that relates to the pressure depends on the algorithm you've selected.
Old   July 11, 2005, 10:02
ag
The normal pressure gradient at the boundary will be proportional to the normal acceleration. You can derive it very easily by taking the normal component of the momentum equation at the boundary.
Old   July 11, 2005, 15:54
Svetlana Sushchikh
To addition : 1. if you apply pressure boundary condition (as recommended), check your surface velocity (see recomendation 1) carefuly. 2. If you want to transfer into body coordinate system, do NOT forget about acceleration.
Boundary Conditions Thomas P. Abraham Main CFD Forum 20 July 7, 2013 06:05
boundary condition for define_grid_motion bongo FLUENT 1 June 12, 2013 04:37
Moving boundary condition (opening) kezman CFX 0 November 13, 2009 06:37
Airfoil boundary condition Frank Main CFD Forum 1 April 21, 2008 19:36
Pressure Boundary Condition Matt Umbel Main CFD Forum 0 January 11, 2002 11:06
