Create hemisphere like velocity profile at inlet
Old   July 10, 2005, 22:23
Default Create hemisphere like velocity profile at inlet
Nelson
Hi Everyone,
I am wandering how to create a parabolic velocity profile at the inlet for a circular pipe flow problem in "3D" in Fluent. I have tried to write a User Define Function (UDF) code for that, but it wasn't successful, which only gave me one parabolic profile when look in side way and uniform straight velocity profile when look from the top.
What I actually want is a hemisphere like shape velocity profile at the inlet. In fluid dynamic terms, fully developed flow at the inlet!
Besides, is that any website that let people download UDF code to solve common problem like this one here?
Thank you very much in advance for reading or answering!
Nelson
Old   July 11, 2005, 12:20
Default Re: Create hemisphere like velocity profile at inl
david
Hi Nelson, you should be able to find what your're looking for under the Fluent forum. Search "Debugging a 3d parabolic profile". The code posted there should do the trick. Just make sure to compile it instead of interpret it as this was the source of my troubles.
Best Regards, David
Old   July 11, 2005, 22:33
Nelson
Hi David,
Thank you very much for replying me, I am a beginner in using this forum, sometimes I just don't know where to find things. The reply is very useful! Thank you!
Best Regards,
Nelson
Old   July 27, 2005, 13:05
vemula
Hi I have the same problem as mentioned by you nelson..its only a half profile..and I dont have acess to the fluent forum ..can you fwd me the code for parabloic profile at inlet to my email ID vemularaj_v@yahoo.com or post a reply....thank you..
Fully developed 3d velocity profile: Square inlet! Taru FLUENT 6 September 14, 2015 09:38
FSI- Pipe- uniform velocity profile inlet Absy Main CFD Forum 0 April 6, 2010 04:01
Specify Inlet Velocity Profile JHardes ANSYS 1 March 17, 2010 14:59
Annular inlet profile of experimental velocity fluid FLUENT 0 December 7, 2007 11:05
inlet velocity profile in Polyflow srinu FLUENT 0 January 16, 2003 21:25
