I have a problem about possion pressure equation |
November 24, 2011, 09:41 |
kanzaki urumi
hello everyone.
I have a problem about my research. my prof. give me a problem to me that i need to resolve this week. my research is about PIV,now i have velocity in x,y axis(u and v) but i know don't how to calculate pressure from velocity i go find in google but i don't understand much, how to use possion pressure equation. i need to know how to use velocity to calculate pressure because i have to write C++ program to calculate its for me and compare to openfoam in next step. anyone have any idea about it pls help me and thank you very much guy. ps. i'm sorry if my english is not correct clz i'm not a native eng speaker. |
November 24, 2011, 13:18 |
#2 | |
Arjun
Rep Power: 34 |
you have to derive continuity equation from velocity, which would be like poisson equation. Solve this by any matrix solver. |
November 25, 2011, 08:21 |
Carlos
Rep Power: 14 |
You indeed need the continuity equation. However that will not be sufficient as only rho and V are the only quantities embedded into the continuity equation. How to proceed largely depends on the type of flow you have. Could you give us some more specifics about the type of flow?
If the flow is for example incompressible, you will need both the continuity and the momentum equation (in x and y direction). The momentum equation is a vector equation and gives you two equations in 2D. Along with the continuity equation you have then three equations in total. The unknowns are then u, v and p. Thus the system is solvable.
"Do not worry about your difficulties in Mathematics. I can assure you mine are still greater." - Albert Einstein |
November 25, 2011, 18:41 |
#4 | |
Arjun
Rep Power: 34 |
November 26, 2011, 10:25 |
kanzaki urumi
thank you every one
now i know how to solve it thank you for advice |
Strcture of pressure correction equation in PISO stable over time ? | sebi | Main CFD Forum | 1 | October 26, 2010 22:19 |
Physical meaning of pressure in pressure eqn | dontknow | Main CFD Forum | 2 | August 30, 2010 10:12 |
A fundamental problem about Pressure equation of the potentialFoam solver | dbxmcf | OpenFOAM Running, Solving & CFD | 0 | October 6, 2006 11:32 |
pressure poisson equation on staggerred grid | chandra | Main CFD Forum | 9 | May 5, 2005 06:01 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
