ULTIMATE QUICKEST
Old   July 3, 2005, 23:18
Default ULTIMATE QUICKEST
Tanaka
Dear all, I am using ULTIMATE QUICKEST (Leonard 1991) for calculation of advection part in incompressible NS equations. My problem is in the limitter.
1. After designating nodes (fi_D, fi_C, fi_U) based on the sign of advecting velocity, I calculated ABS (DEL) and ABS (CURV) where DEL = (fi_D-fi_U) and CURV =(fi_D-2*fi_C+fi_U)
2. I checked if (ABS(CURV)<=0.6*ABS(DEL), if yes, then I calculated the facevalue (flux) using unconstrained QUICKEST scheme (no limitter).
3 Otherwise if ABS(CURV)>=ABS(DEL), then the facevalue (flux) =fi_C and proceed to next face. If no, then...
4. compute the reference face value fi_Ref=fi_U+(fi_C-fi_U)/c;
5 Now SET UP SOME DESIRED HIGH ORDER FACE VALUE (fi_F). if(DEL>0, limit fi_F by Fi_C below and the smaller of fi_Ref and fi_D above. if(DEL<0), limit fi_F by Fi_C above and larger of fi_Ref and fi_D below.
My question is what is desired high order face value (No. 5). Is it different then the facevalue in step 2. (can be calculated using QUICKEST scheme). I do not understand step 5.
If any one is using ULTIMATE QUICKEST scheme,kind help me. Any kind of help will be highly appreciated. Thank you A student
Ultimate Flux Limiter gentela Main CFD Forum 1 August 2, 2016 21:55
[GAMBIT] Install Gambit in Win Vista Ultimate hector ANSYS Meshing & Geometry 6 October 17, 2009 02:34
OpenFOAM141dev linking error on IBM AIX 52 matthias OpenFOAM Installation 24 April 28, 2008 16:49
ULTIMATE QUICKEST scheme Tanaka Main CFD Forum 0 July 6, 2005 23:43
help: ULTIMATE + QUICKEST in 2(3)D Alexej Kornjaew Main CFD Forum 0 January 13, 1999 16:15
